MSI GeForce GTX 1070 Gaming X 8G Overclocking
Using MSI Afterburner, we first set the power limit and temperature limit to the maximum values, which are 126 percent and 92°C respectively on this card.
After much trial and error, we eventually got the core stable with 110MHz added to it, giving us new base and boost clocks of 1,717MHz and 1,907MHz respectively. This is a seven percent increase on what MSI runs the card at in OC Mode. We tried increasing the voltage slider to manage a higher overclock but were unable to get anything extra from this sample.
The memory was able to run at a seriously impressive 9.6Gbps without falling over or showing errors. This is a full 18.5 percent boost over OC Mode's 8.1Gbps.
Nvidia Titan X (Pascal) 12GB
EVGA GeForce GTX 1080 FTW 8GB
MSI GeForce GTX 1070 Gaming X 8G 8GB (OC)
Nvidia GeForce GTX Titan X (Maxwell) 12GB
AMD Radeon R9 Fury X 4GB
Sapphire Radeon R9 390X Nitro 8GB
Nvidia GeForce GTX 980 Ti 6GB
Nvidia GeForce GTX 980 4GB
AMD Radeon RX 480 8GB
AMD Radeon RX 480 4GB
Nvidia GeForce GTX 1060 Founders Edition 6GB
Frames Per Second
Frames Per Second
Asus GeForce GTX 970 DirectCU Mini 4GB
2000
3000
4000
5000
6000
Score (Higher Is Better)
